‎2006-10-05 09:28 AM
‎2006-10-05 11:22 AM
Achille wrote:unfortunately, since archicad and plotmaker 9 are not supported when running through rosetta, this is the kind of issue you may well run into that there are no solutions for. if you are using an intel mac, upgrading to archicad 10 and installing the intel build is the only 'safe' option . . .
The minute i click on "print" plotmaker crashes!!! And it does so with both an Imac and MacPro... i can regularly print from Archicad9...
‎2006-10-05 01:20 PM
‎2006-10-05 11:42 PM
Achille wrote:any application that isn't written specifically for a mactel chips (an "intel build" or a "universal binary") has to run through emulation software in order to work. a bit like virtual PC used to be, but the technology has much improved: rather than emulate the older chip technology, apple have licensed a piece of software called 'rosetta'. it's built into OSX intel systems and dynamically translates older mac chip (PowerPC) software into a format that the intel chips can handle.
do you mean that you cannot run archicad9 and plotmaker together, or that generically they are not supported? because ac9 runs pretty much ok on macIntel...
‎2006-10-06 02:27 PM
‎2006-10-06 02:49 PM
‎2006-10-12 08:50 PM
