Plotmaker 9
Erika Epstein
Plotmaker 9 works without a key
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
6 REPLIES 6
Jefferson
Seriously?
Does it still run a background copy of ArchiCAD for updating pourposes?
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
Ben Odonnell
Plotmaker has always been able to run without a key. But if you try to import a new file it doesn't You still need a key to import new view sets.
Cheers.
Ben
Ben O'Donnell
Ben Odonnell
Jefferson wrote:
Seriously?
Yes it does!
Cheers.
Ben
Ben O'Donnell
Erika Epstein
JEFF,
, there was meant to be a question mark; I was interrupted ...
However, I can customize, add, subtract , edit etc. and save. When I went to import, it even puts in the empty frames! I tried importing both from AC 9 example and 8.1 projects. It imports the empty frames which can be moved around on the layout. After a minute it tells you "no protection key".
I was hoping that this was just an error on the demo I have.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
Ben wrote:
Jefferson wrote:
Seriously?
Yes it does!
Cheers.
Ben
How come you get actual drawings? All I got were empty frames?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Jefferson
Erika,
thanks for the clarification . I was puzzled for sure.
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
