I'm running into a problem in which my pointer becomes the magic wand while using drawing tools such as the line tool, circle, fill etc. This occurs after the tool has been selected and prevents use of the tool (unless, of course, I was planning to use the magic wand anyway). Once this begins, I can no longer move objects with, or in relation to the nodes (snap points). Quitting and reopening doesn't seem to help and the problem will eventually go away, apparently on its own. Any ideas?
