Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Polygon countin' tools
What's the best way for AC11 (on Mac) to determine overall polys in a multi-story model?
1 REPLY 1
The Polycount Goodie should do what you need. You can even select individual or a specific range of storeys if required.
Go to 'ArchiCAD 11 Goodies' on your 'Help' menu in ArchiCAD to launch the download site. Follow instructions to install.
To launch when it is installed go to 'Window' 'Palletes' then 'Polycount'.
