Polyline 3D
mest79
I want to connect points in a 3D view with a line and I use the "morph" tool (method polyline).
Can I view a polyline morph in a render?
Thanks
Architect
AC22 (3006) - i7-6820HQ, 16Gb, AMD FirePRO W5130, WIN10
6 REPLIES 6
This may be a silly question, but have you tried?
It is best if you test it to see if what you model is visible as we have no idea of what it is you are trying to see.
Versions 6.5 to 26
Just out of curiosity I had a look.
Cinerender does not show the hard edge of any elements at all (not even walls & slabs).
So a morph surface will show but not the edges, and a morph line will not show at all.
So unless there is a setting I am missing in Cinerender options, it look as though you will have to combine a sketch render (where the lines will show) with a Cinerender.
Versions 6.5 to 26
Tim Ball
I use the railing tool as a 3D polyline. That will show in renders.
Tim Ball
AC26, iMac
User since V5
mest79
Thanks Tim but I use Archicad 20 and I don't have the railing tool
Architect
You could try a very small diameter round beam (complex profile) for horizontal and sloping 'lines' and a small round column for vertical.
Versions 6.5 to 26
mest79
Thanks Barry, I'll do it your way.
Architect
