Printing PDFs from ArchiCAD9.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-05-18 11:36 AM
‎2005-05-18
11:36 AM
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-18 12:38 PM
‎2005-05-18
12:38 PM
Are you printing or publishing? I've been told publishing is the best way. See if that helps.
Cheers
Cheers
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-18 02:03 PM
‎2005-05-18
02:03 PM
Kristen wrote:
I've recently installed the Tiger operating system on my Mac and have noticed this problem. When I print a file to PDF from ArchiCAD9 (and only ArchiCAD), this image only partially prints and what does make it through is grayed out. I'm using Adobe 7.0. Has anyone else noticed this problem?
I have noticed a similar situation to my printer where I have only been getting partial prints. No Tiger driver available yet
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-19 12:34 AM
‎2005-05-19
12:34 AM
I'm using the Adobe PDF printer driver that comes with Acrobat professional because I was under the impression that results were superior to Mac OSX's printer driver. Everything was fine running under Panther. It's only been since I've switched to Tiger that I've had a problem. I get the same result whether I print the PDF or publish the PDF.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-19 01:21 AM
‎2005-05-19
01:21 AM
I had this exact same problem just the other day.
I resolved this way.
In AC, I usually create PMK's of everything to be printed, rather than importing directly from AC each time. Takes a little bit extra time for Plotmaker to fully load, but I find it to be a lot easier and faster than importing directly from AC.
However, no matter which way it is done, to resolve the problem, I had to create a ViewSet of all views in AC. Don't know why as I didn't have to do this before the latest build. After the ViewSet is created, I then create my PMK's as before.
In Plotmaker, I import the PMK files rather than importing directly from AC. Then if necessary I create PDF's in Plotmaker.
Something quirky in the latest build of AC. I never had to create ViewSets before but now have to in order to get Plotmaker to print properly.
Grant
Grant
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-19 08:43 AM
‎2005-05-19
08:43 AM
Yes, you are correct, there is something quirky going in the latest build of PlotMaker: http://archicad-talk.graphisoft.com/viewtopic.php?t=6782
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
