Problem! An arched opening in a Curved Wall.
When I place a Arched opening in a curved wall(more specifically, an Elliptical Tower), in the 3D view, the opening does not cut through the wall completely. Has anyone had any experience with this problem and is there a solution available.
3 Replies 3
Dwight
No problem with Arched Opening 10
Are you perhaps using the niche instead?
Dwight Atkinson
Wondering, if it is an elliptical tower if the walls are a series of short lengths of curves at varying radii, and therefore the opening spans more than one wall segment? This would cause a problem, would it not?
Dwight
there u go.
Dwight Atkinson
