Problem extending beams
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-07-20
12:57 AM
‎2023-05-26
12:24 PM
Rubia Torres
I am sure I am just not understanding something, missing something or doing something wrong, but every time I extend one end of my internal beam to the edge beam, it extends the other end by itself. What I am wanting, is to have the ends of the internal beam, touching, not overlapping, the inside edge of the edge beam. But it only wants to do this on one end, then it extends and overlaps on the other end by itself, this causes it to be visible in elevation, meaning I need to hide it with a cover fill. I also don't want them to intersect, as this causes the internal beam to bleed through in elevation (cuts a hole in the edge beam), again, I need to hide it with a cover fill. To prevent them from joining I have set the intersection group number for my internal beams layer to 2, and my edge beam number is 1.
Please see the first picture, in this case, I joined the bottom end of the internal beam (the vertical member in the picture) to the inside edge of the edge beam. Then I extended the top end of the internal beam to the upper edge beam. Then the bottom end of the internal beam extended itself to overlap the edge beam, when I readjust this end, the other end extends itself, like a mean game hahaha.
As a temporary work around I have set the internal beams off the edge beams by 1mm. But I know I am missing something and there is a faster (and better) way, I just can not work it out, can anyone help? Either by stopping this automatic extension, or by stopping the internal beam from bleeding through the edge beam, as shown in my second picture attached, when the beams intersect.
Thank you.
Chris.
Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 12:54 PM
Do you extend the beam by moving its end hotspot? If so, instead try using the "Adjust" command and click at the exact point you want the beam to be extended.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 01:23 PM
Thanks for the suggestion, I gave it a go and the same thing happens. It seems as though if they are close to each other they want to overlap.
Thanks again.
Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 01:39 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-24 02:20 PM
Thanks for that suggestion. It still happens. I have sent that job off using the offset back by 1mm method. But if anyone has any other ideas I would love to hear them
Thanks again Braza
Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-26 03:38 AM
Make sure the beam tool is active.
SHIFT select the beam you want to trim.
CTRL click on the edge you want to trim the beam to.
If it is short, it should extend to that edge.
If it is long it should split and you can delete the bit you don't want.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-28 11:45 AM
No this dosent work either, it just 'dings' at me.
I also think it is strange it doesn't "merge" with the beam also, it kind of overlaps it. Maybe this will give an idea to someone?
Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-28 12:03 PM
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-08-01 01:16 AM
that did not work either, I can extend one end fine, but then the other end extends to overlap on its own, then when I pull that back, the first end extends to overlap on its own.
I tried to upload a video, but I guess video formats are not available.
I want to thank you guys for your help, but I think I will just accept that I need to keep the internal beams back in 1mm. It is only for quantity reporting for the estimators anyway, and they round up so it wont be too much of a problem.
Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-08-01 07:47 AM
