I'm trying to make a custom symbol fill (following these instructions : http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/documentation/fills/create-o... ), and I'm running into a problem. When I go to paste my pattern into the fill editor, nothing shows. It just goes yellow and there is no number in the "motif size" boxes. No matter what I do to the spacing dimesnsions of the fill, nothing shows up. Thanks!
The yellow represents your Pattern Unit, which is the pattern that repeats itself within the fill. Yours is simply much too large. Scale it down. I recommend doing this at a scale of 1:1 and setting the origin on the project origin. It should only be a few inches/cm wide.
Thanks for the response Link
I just tried resizing the fill, i scaled it way down so it's only a 70mm x70mm square (it was only 700 x 700 before) and the problem still persists. I've tried resetting the origin as well, and nothing is changing. I've even tried it in a brand new empty file, and same result
The fill pattern is super simple, just it's exact to a particular assembly we are using.. The tile size should be a 700 mm x 700mm square . I'm uploading a module file with the hatch pattern i'm trying to use. Thanks for the help!
One of my first posts to (the old) ArchiCAD-Talk explained how I figured out that if you take your cursor all the way around the edge of the screen you could finally place it in the X coordinate of the Coordinate box. Then you could enter an X direction.
Hi, I've got the identical problem, but I'm using only lines and hotspots. It's a 20" square motif, and when I click paste it does change to 20" x 20", but no lines.
AC fan since v 7. Currently on AC 26 Build 5003 USA FULL, and AC 28 Build 3110 USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Ventura 13.7
