Problem with intersections
Hello.
Still cant figure out this new materials and composites system.
I have two walls in same layer. One of them is concrete wall with insulation and other one is brick wall with same insulation. Concrete priority is 750 and brick priority is 560. Insulation priority is 210 (same insulation both walls).
Why i cant intersect them normaly?
What settings should i use to get desired intersection (like in picture below)?
1 Solution
If you want the finish to be continuous then you need to make it stronger than the other core materials.
The strongest material will cut the weaker ones.
The more skins you have the more complicated it gets.
I am finding that it can be beneficial to have two strengths for each Building Material.
i.e. duplicate them and make one strong and one weak.
This is useful when you have the same finish inside and outside - make the inside one weak so it does not cut through the other skins and the outside one strong so it does cut the other skins.
Also if you have a cavity in your wall construction make that the strongest of all if you want that cavity to always be continuous so it does not get cut by other Building Materials.
Go to post
4 Replies 4
Surki,
stronger (higher number) priority will overwrite lower priorities, if you want the insulation to be continuous it will need a higher priority than the other materials
Scott
It works, thanks. Now i only have to make my new template
Katalin Borszeki
Hi Surki, is your problem solved then? If not please write a private message and I will provide you with a link to upload the file to troubleshoot. Thanks, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
