Problem working with 3D
Hello there.
I am using Archicad 16 3006 INT.
I have a Macbook pro
Snow Leopard OS 10.6.8
2Ghz Intel Core i7
8GB 1333MHz DDR3
Every time I am working in 3D it crashes when i select an element or try to move/ elevate/ draw something regardless of the size of the project.
I had the same problem with Archicad 15, too.
Thanks in advance.
4 REPLIES 4
I have not had this experience with AC15 or AC16. Just have to ask if you are working on a licenced version and not a crack.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
I am using a licensed EDU version of archicad 16.
It is very annoying because in archicad 16 you are supposed to work at 3D a lot.
Do you know who can i ask if find no answer here?
You say you're running build 3006. In the EDU version, does Help > Check for Updates not show the 3014 hotfix:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes/AC16-3006to3014-ReleaseNotes.html
Try updating to see if that resolves the crash.
Otherwise, it might (??) be because you are still running Snow Leopard? This page:
http://www.archicadwiki.com/ArchiCAD16#Compatibility
does say that 16 should run on 10.6 but also notes that Graphisoft did not test that version of OS X.
Other possibility... you didn't give the exact model ... but does your Macbook Pro graphics card have the option of 'switching' between mobile and high performance modes? If so, select high performance and see if that helps...
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Karl Ottenstein thank you very much for your time.
I am using the latest version of Archicad and the problem exists.
I tried changing graphic change but i saw no difference.
I am thinking of doing a format on my operating system.
I had the same problem with archicad 15 so is it possible to be a hardware problem with the graphic card?
On the other hand no other problem (e.g. sketchup, c4d) has problems with 3d Working. Archicad 16 Browses 3d without any problem but when i click a node in order to modify an element it crashed everytime.
