2019-10-15 06:14 AM
2019-10-15 11:06 AM
2019-10-16 02:02 AM
Christophe wrote:
It seems to be a 3D document which is related to a 2D plan view
Try to create another 3D document view after changing your north to check it
2022-02-07 01:02 AM
I am experiencing exactly the same issue you had years ago. Would you happen to know the answer by now? Thanks.
2022-07-07 01:50 AM
2022-12-08 03:11 AM
Came across this whilst testing out our new office template in AC26 and running into the same issue. i.e. Any premade shadow diagrams (3d Docs) will have their north orientated to the direction of project north was when it was created.
We found that we could 'reset' each 3D document by going into into 3D Document Settings > 3D Projection. And without changing anything, OK out of both. This will get the view to recheck and re-render the shadows.
Annoying, but beats completely remaking the 3D docs. Also applies if, for whatever reason, Project north needs to be modified.
2023-06-21 03:32 AM
this worked for me
