‎2020-01-1706:13 PM - last edited on ‎2023-05-0904:17 PM by Rubia Torres
‎2020-01-1706:13 PM
hi all,
I have some questions about topics emerging around the "Building Materials" window:
- Where does the data for the Physical Properties came/come from?
- Is there a way to disable automatic intersection/merge behavior between walls/slabs with the same material? (see screenshot below)
- What are known use cases where one needs the material classification (IFCMaterial)?
The first and last question is quite a bit to answer and there is enough information out there. I recommend next time to do a google search first before asking this type of questions here.
