Srinivas
Radial Dimension on Objects
Just wanted to check if I am missing something the regarding Radial dimension tool in ArchiCAD, I am using the Radial Dimension Tool to show dimension of a curved object on plan but its not identifying the object to show Radial dimension, where as it is identifying curved walls on plan to show the Radial Dimension.
It seems that you have to draw an arc and radial dimension it and hide the arc to fake the presentation.
Can any one kindly let me know how they are doing it in similar situations.
Thanks for all your help.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
3 Replies 3
Erika Epstein
You could amend the 2D script to have a dimensionable arc i.e. putting the faux arc into the object as opposed to it being a separate element.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
rocorona
All old users of ArchiCAD know that the cursor can only recognize the Hotspot, for the library elements, no lines or other nodes than the ones defined in the scripts.
In the last few versions of GDL, there are new commands that allow lines and arcs to be recognized (thus dimensioned, I assume...), but the majority of the standard object do not use them.
If you want to add these commands to your object, search for HOTLINE2 and HOTARC2 in the GDL user manual.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Erika Epstein
That's what I meant.
an old user
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
