Kikoria
Railing connection
Hi. I was wondering how it is able to connect the closed railing. You see all the three nodes are perfectly connected while the fourth one remains unconnected.
Kind regards,
Tamaz Kikoria
Architect
Technical Examination and Design Department
GEORGIAN WATER & POWER
3 Replies 3
Railing does not connect, you will need to end the nodes parallel on the same node
The recommended solution to this situation is to start and end the Railing somewhere along an edge of the polygon, not at a corner. So, for example, start the Railing in the middle of the longer edge, and also end it there.
Kikoria
Yes, that's the only option, I guess. But I was wondering whether it was possible the other way. Thanks for your reply!
Kind regards,
Tamaz Kikoria
Architect
