Railing tool problem
Hi everyone.
I have faced with the problem when moved to the AC24. The railing toool is not working proper, actually is not working. Namelly - I can create a railing and that it. There are no chance to change the frame, panels, handrail etc. The only shape as you can see on the attached picture. Material is class for whole model and no change possible. there no differance what shape - bended or straight. What problem is that?
Thanks in advance.
1 Solution
runxel
Check your MVO. Most probably you've accidentally set it to only show a simplified representation of railings.
Go to post
runxel
Hi. Thanks a lot. Now it works.
