2017-06-14 05:33 PM - last edited on 2023-05-23 06:05 PM by Rubia Torres
2017-06-16 07:39 PM
2017-07-02 11:02 AM
2017-07-03 03:07 AM
2017-07-03 09:19 AM
2017-07-03 09:46 AM
2017-07-03 03:33 PM
2017-07-03 08:25 PM
2017-07-04 12:42 PM
2017-07-04 05:16 PM
2017-07-06 03:26 PM
ispyridis wrote:A single Stair's Risers Height and Going Depth is always the same when it is placed. In Edit Mode it is possible to move all Risers to some other position (please note that this will not modify the Structure), and it is also possible to select any Tread and modify the tread Height individually.
Hi Barry,
I did try all these, it is nor that flexible, it locks the riser height thus resulting in certain inclination, does not play with the range of riser. Maybe the problem is in RC1 release, still haven't got my upgrade.
And by the way, I was thinking that this should be implemented for the concrete stair structure. Also to control if the difference in height is very small and the length of tread large, to turn to ramp for that segment.
Regards
