2017-06-14
05:33 PM
2023-05-23
06:05 PM
Rubia Torres
2017-07-06 10:47 PM
laszlonagy wrote:Stairs should connect just two different points. If too steep tends to be ladder if too lowly tends to be ramp. Depending on inclination the structure changes too, rarely you can find steep concrete stairs and if you do they mostly have an inset at the riser to accommodate for short going, but you can find steep steel stairs with stringers or central beam.ispyridis wrote:A single Stair's Risers Height and Going Depth is always the same when it is placed. In Edit Mode it is possible to move all Risers to some other position (please note that this will not modify the Structure), and it is also possible to select any Tread and modify the tread Height individually.
Hi Barry,
I did try all these, it is nor that flexible, it locks the riser height thus resulting in certain inclination, does not play with the range of riser. Maybe the problem is in RC1 release, still haven't got my upgrade.
And by the way, I was thinking that this should be implemented for the concrete stair structure. Also to control if the difference in height is very small and the length of tread large, to turn to ramp for that segment.
Regards
However, what I would do is I would probably model such a Stair using multiple Stair elements.
By the way, a Stair is not associated to a Mesh and Gravity is not available as an option when placing Stairs.
2017-07-08 10:38 AM
2017-07-08 11:20 AM
laszlonagy wrote:Hi Lazlo yes I will make my description as a wish.
If you think this would be an important feature, please make a wish for it and I will submit it to GRAPHISOFT for their consideration.
I agree that an algorithm could do this, I just don't know how many people would find this useful because this sounds to me like it would be useful mostly for a landscape architect.
Additionally, the Stair Tool would have to be made to be able to be associative to Meshes for this to work.
2017-07-08 08:05 PM
2017-07-08 10:14 PM
vfrontiers wrote:Hey Duane! The only way I can replicate that behavior is if my second click on the first leg is beyond the total run of the stair (based on riser/floor height). When rubber banding, I see the stair treads stop ... and clicking just completes a straight run. As long as my second click is while there are remaining treads, then I can turn the corner while the stairs continue to rubber band.
Any idea why I can ONLY create a ONE RUN stair? no matter what I do, it won't allow me to turn the corner and create an L shaped or U shaped stair...
2017-07-09 04:40 PM
2018-03-08 10:25 PM
