Random Lines on Mod files from web.
As the title says, I have downloaded a Mod file from a web site, and when i opened it I get random lines that are linked to some line or some object on the detail but cant select it unless I find that item it is linked to..
http://pokit.org/get/?871b19f2ea18739b34310e0da8cc4acc.jpg
I am using the V12 an the detail is V11 so there shouldnt be any issues that way I would like to think....also tried to open the same Mod file in V15 same issue
3 Replies 3
It looks a bit like the Hedge linetype or something similar. Have a look at your Linetypes and see if there is a strange one that was not there before you added your mod file. Or you could use Find and Select to select all lines that are NOT solid linetype, deselecting any others that may still be selected until you only have that one left.
ty worked, seemed like some lines where changed somehow to the hedge line type.
It will be that your attribute ID within the mod file corresponded with the hedge line type ID within the host file.
