Random Rotation Problem
Why does this happen? (See below) We are using a GDL that comes with ArchiCAD, but modified to be a circle. Occasionally, the text will rotate itself. If you go to the object settings, it says the object is rotated 0 degrees. Sometimes if you close and reopen the file, it will correct itself. But sometimes it's persistent.
Has anybody else seen this?
Erika Epstein
"We are using a GDL that"
Could you please be more specific as to which tooland settings are you using?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
It's "Keynote Indicator NCS.gsm" copied and changed so it has a circle instead of a hexagon. It's used with the label tool to create the annotation you see in the graphic.
