Re:HELP!!!anotherBIG BUG
My ability to pick a line, edge, point, rotate seems to have decided to be offset by some arbitrary length. I can't rotate by picking the roof edge, wall ends because of this offset. I can't move an opening in the roof (for a skylight) because of the offset.
I don't know where to stop this, looked at mouse constraints, and everywhere else, but can't figure out what setting has been turned on, or what.
HELP
Eduardo Rolon
Check that you have not turned on Grid Snap.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Figured it out.
Had to change to Apple Magic Mouse (bluetooth); restart ArchiCAD (who knows why) and reset mouse constraints (somehow got changed to Mac-classic like) probably when I was in panic mode.
Had been using an early version "Magic? Mouse" that involved holding the "control" key to get a "right" click operation...which sometimes did not work.
thanks for all suggestions
Grid snap is not on, mouse constraints are "cad like" 5 pixels, any more ideas?...this is driving me nuts
