Re: is there a way i can make slanting walls
is there a way i can make slanting walls or will i have to use the roof tool only.
please advise
6 REPLIES 6
create a normal wall
select it
extras>accessories>wall accessories: canted wall
you can't delete the 'parent' wall as the canted wall is defendant on it and will be deleted too. you can make the parent disappear by giving it a 100% transparent material, white pen outline and empty fill
if the parent wall has door/window openings then the canted wall will inherit them
doors and windows can be offset from the parent wall into the canted wall but will always be vertical
editing the parent wall should update the canted wall but it can be a bit flakey
the canted wall parameters can be edited with the object tool settings
bill
Dwight
And the Solid Element Operation is quite effective - or using a roof element to trim over and under - this approach can be controlled to not affect opening frames.
Dwight Atkinson
You may also put the parent wall on a different layer and hide the layer if no doors or windows are associated with it. If there were, you could save a few windows as objects, tilt them and place them in empty holes in the canted wall... or you could use the canted curtain wall library part (with the Object tool active go to the window section of the ArchiCAD library and you will find them).
Have fun
defendant?
doh
bill wrote:
defendant?
doh
Well.. I guess you could say that!
Dwight
here's a tilted wall made with two "trim to roof" actions.
Dwight Atkinson
