Reducing the size of multiple text frames at one go
Due to too dense dashed line in this particular floor plan, I had to change the scale of the drawing from 1:10 to 1:100, all texts became obiviously too big after that.
So I reduced the text size by 10times, and all went ok except the text frames that have become very long.
Is there any way I could easily change them at one go, not to resize them one by one manually?
thanks!
Select all of the text and turn of the 'Wrap text' option in the settings.
Then you can turn it back on if you want to.
Wow, thanks mate! it worked..
