Refrences for drawing lines
Hi all,
I am new with Archicad! Before I always used Revit, but I want to learn Archicad.
Only I have a problem with measurements. For example I want to draw a floor where the points are always 750mm from some walls, I can only acomplish this with a lot of steps. But I think it should be easy.
The problem is the distance is always measured from the previous point, but is it possible to measure from a reference point?
So see image for a more clear explanation.
Now I get it only done by drawing the floor line on the wall and when it is finished I move all the points 750 from the wall.
Greetings,
Bram
Attachment is not working so here a link to the image:
4 REPLIES 4
DGSketcher
Legend
Have a watch of this tutorial by Eric Bobrow...
https://www.youtube.com/watch?v=nX9NIFd93W8
You can set a start point relative to a known point by doing the following:
Hover cursor over a known node or edge
Type "X (distance) +" then hit Enter (excluding quotes)
This will move your cursor your distance to the right of the original start point.
"X (distance) -" Enter will move to the left
"Y (distance) +" Enter will move Up
"Y (distance) -" Enter will move down.
In your case hover over the corner of the existing wall and type in "Y 750 + Enter"
You can do this before starting to place a wall, for example, or draw a line, or you can use it to move an existing element to a point relative to something else.
(this sounds complicated but it is not, and you will get the hang of it very quickly)
Thanks this video was really usefull! I need to use the + and - for the distances to do the trick
Thanks for your explanation! The + and - sign where the ones I did not know about, and it makes drawing much easier
