ngoldie
Relative coordinates tracker input problems
When I input the first dimension into the relative coordinates tracker it isn't defaulting to distance first, I have to toggle down every time. Is there a display setting I can change to make this display right and automatically have the degrees visible as well? I'm on a macbook pro, it is Archicad 21 and I'm operating on MacOS Big Sur
Thanks.
Screen Shot 2025-04-21 at 8.40.35 am.pngScreen Shot 2025-04-21 at 8.40.50 am.pngScreen Shot 2025-04-21 at 8.40.10 am.png
Archicad 20
MacBook Pro - laptop
1 Solution
Matteods
Hi
For sure is possible. You can check the tracker setting.
https://help.graphisoft.com/AC/18/INT/AC18Help/Appendix_Settings/Appendix_Settings-7.htm
Greetings,
Matteo
Go to post
Matteods
Hi
Greetings,
Matteo
ngoldie
Perfect thank you!
Archicad 20
