Reno status in details
Occasionally when I take a detail off another drawing (in this case off a section) some of the elements in the detail go a little wonky, almost like they're on a demo filter. But all the elements are on the New Construction filter. Any ideas? Won't let me change some settings of the detail, and the section looks fine.
Brad Elliott
I've had the same issue but all my lines turn green. I get it when opening source view from a layout. Closing it and opening it directly through the navigator seems to clear the problem.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Seems weird enough.
Maybe it was saved when you had an override on and it got stuck?
Does the same thing happen when you close all other tabs and use Rebuild&Regenerate?
Does it look fine on a layout?
Otherwise, it might be a bug. Could you send me over the project so that I can take a look?
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
