Renovation Filters
I have ongoing issues with the renovation filters, and it's driving me crazy!
See attached image- the walls are existing and hatched in black on the existing renovation filter. How do I get existing doors to show and cut through the wall as per standard construction documentation?
I have tried all floorplan display options (symbolic, overheads etc) with no luck- i'm sure theres a very simple solution that i'm missing.
I'm currently using ArchiCAD 21 on a PC.
Help!
3 Replies 3
David Maudlin
Caitlin Torrington:
This could be the symbol fill, look at Door Settings > Floor Plan and Section > Use Fills on Symbol an Section.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi David,
Thank you for your reply- unfortunately it's still not working. See attached snapshot of the wall and door settings. Any ideas?
David Maudlin
Caitlin:
In the USA Library it is here, there should be a similar setting in the AUS version. Also, are all your pens set to black?
