Strawbale23
Renovations and openings
Hi, just wondering what the "correct" method ppl use for changing windows and doors for renovations.
Currently I:
-Copy the existing opening and save its settings.
-Set the existing door to be  demolished. It disappears on Planned Filter
-I create a replacement door using the demolished doors settings.
-I change the door as required to its refurbished configuration, which often means the that the doors dimensions resets and I have to change it back to the desired custom dimension of the existing door.
-I set it as  New Status for renovation filters.
Is there a better way to renovate an existing door or window that isn't going to change dimensions?
Thanks
AC26
https://www.zendsign.fr/
For the door changing size & elevation check this article for excluding or including those parameters to be transfered when pick up & inject :
https://helpcenter.graphisoft.com/user-guide/88505/#XREF_12336_Parameter_Transfer
AC 29 INT 4006/WIN 11
Strawbale23
Thanks. There doesnt seem to be a way to select shading devices.
AC26
