Display malfunction of Graphisoft ID dashboard
Learn more
StarBoy
wall tools creates separated walls
When I draw walls with rectangular, chained wall tools it creates separate walls not joint wall. How to fix it. Archicad 26
3 Solutions
Marcus Scott
Try heading to the View Menu > On Screen View Options and checking the option Clean Wall & Beam Intersections on
Go to post
ryejuan
1. Go to Windows Menu choose Toolbars -> choose Arrange Elements
2. On the Arrange Elements Toolbar activate Auto Group then every time you do a chained wall etc. it will automatically be grouped.
WINDOWS 11 PRO
Go to post
StarBoy
Thank you. I am just trying to follow the tutorials.
Go to post
9 Replies 9
Check the layer intersection group number if it's  assigned to 0 change it to any number other than 0.
AC 29 INT 4006/WIN 11
StarBoy
I think all are set to 1,  
That's because the thin skin at the composite edge I'm sure it's priority is higher than the rest, select the wall & check BM if higher then make it lower or duplicate and change the copy to be lower.
Marcus Scott
StarBoy
Thank you it solved joint problem but walls are still separate created.
Lingwisyer
Guru
Toggle Groups (Alt + G)?
Though, given the nodes are black, it would appear that they are not grouped. You can create a group by making a selection then using the Create Group (Ctrl / Cmd + G) option.
That is it.
Rectangular and chained walls are in fact single walls that are grouped.
Turning the grouping on/off will allow you select individual walls or the group that was drawn with the rectangle or chained command.
ryejuan
WINDOWS 11 PRO
StarBoy
