‎2022-06-22 08:40 AM
Hi there,
I've run into the following issue:
I have a complex shelf which I create using INSCTGROUP.
But everytime I place the result, I want to be able to change the thickness of it by defining the Value of Z before placing it. Like you could do with Gosub
However it keeps the demensions of the first time I defined Z.
Killgroup leaves the Group empty so I don't know how to make this work.
The script is just as an example:
for i = 1 to 5
addz 2
Gosub "Block":
next i
del top
END
"Block":
GROUP "Base"
Block A ,B ,zzyzx+(0.1*i)
ENDGROUP
GROUP "Operator"
Rotz 45
del 1
ENDGROUP
Result = Subgroup("Base", "Operator")
Placegroup Result
RETURN
Is there any way to get around this problem?
Solved! Go to Solution.
‎2022-06-22 11:57 AM
Hi Arnaut_2604,
Within a script each different group shall have a unique name, even if you kill a group you can't reuse it for a new one.
So you have to create a new name for each group.
You can use the i value to do this, see the example modified below.
Hi Arnaut_2604,
‎2022-06-22 12:31 PM
Brilliant! Thank you!
Didn't know I could make a name which would change with every loop
