rob2218
Resetting where your snap grid origin occurs?
here's the question:
Archicad 12.
I was shown once how to reset the "snap grid" to where I need it to be as it relates to the RCP plan for laying in the acoustical tile lines as well as the diffusers and return grilles.
I completely forget and cant' find in the manual where to adjust the snap grid so I can move it around and get it to a corner of the room.
How best to do this?
(see image below)
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
4 Replies 4
Hi Rob,
The 'user origin' can be placed by either clicking Alt & Shift then hovering over a node, or by clicking the origin button on one of the toolbars. (the button with an x).
A search in the AC help files for 'user origin' will bring up full instructions.
rob2218
thanks, will look for the full instructions. appreciated sir.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Changing the position of the user origin won't alter the grid position.
You want the "Set rotated grid" command but when you set it just go horizontal instead of on an angle.
You can then swap any time between the standard and rotated grid (or in your case the standard and repositioned grid).
rob2218
thanks guys....I'll have to try it.
I have a ceiling grid I need to add to a slab object which is 2" thick to represent a "celing grid" condition.
so, i'm gonna try the "rotated grid" variable and see what happens.
i>u
Edgewater, FL!
SOFTWARE VERSION:
