Curtain edit 2D
Hi All,
I am was hoping that somebody will put some light on this curtain wall tool.
The edit 2d mode in the 3d window and plan WON'T work. The tool is still asking to go to the silly menu to edit the curtain wall. I need to mode the mullions around on a specific point and it is alittle bit cumbersome to do it in the 3d edit mode.
Am I missing something??
Tahnk you
DDJUSA
The only 2d editing available at the moment is to modify the position of the reference line, and to add additional points to it. The position of the mullions still can only be adjusted in the 3d window I'm afraid. It's a pain, and hopefully something they will improve in future releases because the floorplan is the obvious place where you would want to edit the mullion positions!
A workaround could be to place temporary walls at the points where you want the mullions to go, and then use those to snap to when editing in 3d.
Peter,
Thank you!! Hopefullt GS is taking note of this.
If you go into the GS website there is a video showing the 2d editable curtain wall!! Well let's wait!!
Thank oyu
DDJUSA
