2007-07-03 12:35 PM
2007-07-03 01:16 PM
2007-07-03 01:30 PM
Remy wrote:
are the story settings the same? If so I's load them as a module
2007-07-03 01:37 PM
2007-07-03 05:54 PM
whatever wrote:I see you have AC11. Use multi-story hotlinks/modules.Remy wrote:
good.. but what if the story settings are not the same?
for me i never needed plans together.so usually i save them as objects because i am just interested in 3D , but what about full documentation?
2007-07-03 05:56 PM
Remy wrote:Even in AC10 you don't have to go to all this trouble. You can import the modules to each story and move them up and down in 3D (or section/elevation) to fit.
you've got a problem![]()
You can match the story settings by adding some empty levels... Or you can try to make it an object (I'm not fond of that because it's not a live model anymore)
2007-07-03 06:39 PM
2007-07-03 08:01 PM
2007-07-04 10:11 AM
whatever wrote:Yes, of course, the FPCP can mess you up if you are using projected walls and the floor to floor discrepancies are too much to adjust for.Matthew wrote:whatever wrote:
mm..i don't have a project right now..and i know asking about this makes no sense... but just wondering... so if i have 2 buildings A and B , in A hights are "4 m each floor " and B " 3 m Each floor "? i don't think this can be solved easily? " unless we are talking about changing FPCP ? or no.. even that won't solve the problem for elevations and 3D?
ooh... maybe i'll just wait till i have a project of that type.. or at least time to try it
