!Restored: Bug: Detail Markers, Boundaries, etc
kevin b
Is there any way to get a rotated rounded rectangle that follows the actual boundaries of the area you are detailing and has the marker head horizontal?
I can get the bottom one, which doesn't conform to the outline of the area being detailed (with a lot of work) and I cant get the marker head horizontal.
Or I get the top one which doesn't have rounded corners on the boundary line and there is no line connecting the marker head to the boundary.
Am I missing something? I could even live without the rounded corners if I could get the line connecting boundary to head.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
8 REPLIES 8
Laura Yanoviak
I'm still on AC11 -- so I can't answer for AC12 -- but, there is a parameter in the Marker panel under Marker Geometry called "Show Marker Line" which controls the line that you refer to.
kevin b
The show marker line option disappears when you select the Clip Polygon boundary
kevin s burns, AIA
massachusetts, usa
Windows 10
Laura Yanoviak
Huh -- it didn't in AC11. Looks like a case of "breaking something whilst fixing something else."
Link
I think this actually broke between AC10 and AC11.
GS is aware of it.
Link.
Laura Yanoviak
Really? Then I must have inadvertently fixed it when customizing the AC11 markers for our firm
Link
Excellent! Quick - send it to Graphisoft!
Link.
kevin b
And more importantly how did you do it?
kevin s burns, AIA
massachusetts, usa
Windows 10
Laura Yanoviak
OK -- From what I can tell from my notes, I found the AC11 Built-in Detail Marker problematic, so I reverted to the Detail Indicator_NCS from the AC10 Subset library and made the necessary adjustments so that it was compatible with the new AC11 features. I suppose GS could do the same...
