‎2007-03-10
10:27 PM
‎2023-05-25
06:15 PM
Rubia Torres
‎2008-07-17 10:44 PM
‎2008-12-08 02:33 PM
‎2009-06-24 06:14 PM
Srinivas wrote:YA.H.VE wrote:Did you try this? Please see the attached Image.
I will love to make a glass corner window with frameless!
‎2009-06-24 09:09 PM
‎2009-06-26 05:15 AM
‎2009-07-07 11:35 PM
Peter wrote:I did find the custom corner options in standard window settings and like you mentioned, they react better with complex walls. I then found the glass corner option among fixed windows only too. So, that concluded my opinion on corner windows - TRASH. We will remove the corner window tool from our office template at the next upgrade. Maybe AC13 will provide better corner window functionality and options.
The frameless (glass-to-glass) corner window option is still available in AC12 but only on 'fixed' windows.
Fully automatic corner window functionality doesn't work on complex profiled walls (see here). You can however place normal windows with one side set to 'corner window' and place them individually. This can be done in the 'corner window' section (introduced in AC12) in the window interface.
The above info is based on the INT version of the windows. I presume other versions are similar.
