ā2008-06-15
07:35 AM
ā2023-05-25
04:57 PM
Rubia Torres
ā2008-06-16 08:51 PM
Bricklyne wrote:Actually, I've found the profession
Good thing you're in architecture; no laughs required here......
ā2008-06-16 08:56 PM
mikem wrote:Mikem, I fully agree that Stairmaker has its problems, however if I were to decide, I wouldn't want the nosing parameter to add anything to the tread depth. I'd just like it to move the riser backwards.
In this image of the same stair with a nosing overhang. Note how the additional tread width has been added in front of the riser rather than at the rear of the tread with the riser moved backwards.
This behaviour must create havoc on winder stairs with the consequence being that they are not modelled correctly.
ā2008-06-16 09:28 PM
Mikem, I fully agree that Stairmaker has its problems, however if I were to decide, I wouldn't want the nosing parameter to add anything to the tread depth. I'd just like it to move the riser backwards.Stairs are measured nosing to nosing here in the USA and the guardrail is measured at 42" vertically from the tip of the nosing. If the guardrail is set back an inch from the nosing, then it's too low and there's problem. Archicad should reflect that. If it doesn't...
ā2008-06-16 10:39 PM
william235711 wrote:Sorry, I wasn't clear. By tread depth I meant the nose to nose distance. The nosing parameter shouldn't change that, it should just push the riser further back like you said. That of course adds to the actual material width of each step, but it should not affect the flight length. And it doesn't in Stairmaker. I haven't tested the guardrail issue though, we have a couple of different standards here in Sweden. It's quite possible to change the height to what you want, in Stairmaker. And in AC12 a few other long-standing Stairmaker problems are gone.Mikem, I fully agree that Stairmaker has its problems, however if I were to decide, I wouldn't want the nosing parameter to add anything to the tread depth. I'd just like it to move the riser backwards.Stairs are measured nosing to nosing here in the USA and the guardrail is measured at 42" vertically from the tip of the nosing. If the guardrail is set back an inch from the nosing, then it's too low and there's problem. Archicad should reflect that. If it doesn't...
Mikem, I fully agree that Stairmaker has its problems, however if I were to decide, I wouldn't want the nosing parameter to add anything to the tread depth. I'd just like it to move the riser backwards.This isn't consistent with how plan sections are cut. If we cut the wall 5 feet above the floor, then everything we look at below should be consistent. This is the 2-d/3-d bifurcation that drives me crazy about Archicad. It should be consistent. The steps should be drawn as you see them from above from nosing to nosing. And where are the railings? I need to show the plan examiner guys that I have 36 inches (or more) of clear exit width.
ā2008-06-16 10:43 PM
william235711 wrote:In AC12, as I said.
ā2008-06-17 01:25 AM
B067050: Stair definition logic is wrongCan one of those who already have Archicad 12 check and confirm if this logic flaw has been corrected, and post similar images to demonstrate that it has been fixed.
ā2008-06-17 01:39 AM
mikem wrote:Does this help? I've exaggerated the nosing for effect.B067050: Stair definition logic is wrongCan one of those who already have Archicad 12 check and confirm if this logic flaw has been corrected, and post similar images to demonstrate that it has been fixed.
ā2008-06-17 02:08 AM
ā2008-06-17 02:40 AM
