Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
!Restored: New ArchiCAD 11 Hotfix (build 1200)
Dear ArchiCAD-Talkers,
A new Hotfix for ArchiCAD 11 (build 1200) is now available through the Check for updates... command. It applies to Commercial, Educational and Trial licenses too. Currently English language versions are available, others will follow soon.
Gergely Kmethy
23 Replies 23
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Tom wrote:
Doesn't this already exist? I'm pretty sure I've had a window telling me that Archicad isn't up to date come up before. Although it might just be for the Archicad library update, in which case it would make sense for it to be for all updates.
ArchiCAD does have automatic update built in. You can control it from Work Environment /Company Standard Schemes /Web Options Under 'Check for Updates' you can set if and when should ArchiCAD check for updates. You can also set it to check only for Library updates, for ArchiCAD updates or both.
When you install ArchiCAD, you are also asked to allow/deny this option. And you still have the 'Check for updates' command in the Help menu.
The http://tr.graphisoftus.com/ is more of an archive managed by our US team.
Gergely Kmethy
Chazz
The man is right..... which I guess shows why he wears a tie and works for a software company and I just work with software (and can't even tie a tie).
Thanks Gergely, I must have turned it off ages ago.
Nattering nabob of negativism
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
I think the last time I wore a tie was when that picture was taken about 3 years ago
Gergely Kmethy
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
We have released a newer Hotfix: see http://archicad-talk.graphisoft.com/viewtopic.php?p=116376#116376
Gergely Kmethy
