Right clicking - no option for Open Section
In some drawings when I right click on a section marker I get the option to open the section, but in other drawings when I right click no option comes up to open the section.
Why doesn't it give me the option to open the section when I right click it?
Thanks in advance for your help.
New user
The section marker with no 'open' option must be and 'unlinked marker' type section ... simply a 2D symbol. See attached. Select the section marker, do a ctrl-T/cmd-T to see the settings and check there. (Depending on your Info Box setup, you can check there as well.)
One of the forum moderators
Yes I had a look and it seems it doesn't have a reference.
I will delete the dud ones & do new ones.
Thanks
