I seem to have a recurring problem with the roof accessory. When the accessory is applied (in our case mostly using the Cadimage Roof Builder object) the resultant object has hotpsots in 3D, but no dynamic hotspots in 2D, just the four corners and the centre. It is happening on two separate machines.
Not only does this make selecting objects difficult when the hotspots are outside the irregular boundary of the roof, but modifying properties that the Cadimage object only accesses by the dynamic hotspots (eg, soffit distances and downpipe setouts) is not possible.
Has anyone else encountered this problem? Or got a solution?
Matthew Johnson - POWE Architects
AC4.5 --> AC29 & Revit 2016 --> 2026
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit + Quest3
I'd rather be sailing.
