Roof Accessory not showing in Section
For some reason the roof accessory on my model is not showing in one section but is showing in other sections. All sections have the same layer combination and I have checked that the roof accessory is on. Any ideas or suggestions why this is?
Thanks
3 Replies 3
Erika Epstein
could you have two instances of the roof accessory on the one roof section where it doesn't show?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I assume you using cadimage accessory,
I had a similar issue the other day and only way to fix it was to remake the roof cladding.
What was happening was the cladding was showing up in section 1 & 2 but not section 3, 4 ,5. The weird part was that if I moved section 3 to the location of section 2, the cladding would show up but when I moved it back to its original location, it would disappear again
I have had this happen too. Creating a new one fixed the problem.
