SOLVED!
Beams not showing in section or 3d
Mac_the_arc
Im trying to get a beam to show in section. I know it is there from the blue line and black dot. I can see the columns it needs to connect to.
2 ACCEPTED SOLUTIONS
Solution
The Building Material material priority will need to be higher than the BMAT's of the wall.
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC29 | WIN 11 | Ultra 9 285K, 3.7Ghz | 64GB Ram | RTX4000
Solution
Or change the Layer intersection priority for the layer your beam is on.
Director | Skewed
6 REPLIES 6
jl_lt
Ace
is there a wall that doesnt show because there is a window the same size of the wall?
no, ive hidden the wall for the purpose of the query
Solution
Director | Skewed
Solution
Director | Skewed
Thanks you, I changed the layer intersection priority and now these are showing. very helpful.
Changing the layer intersection priority also means that you overide the material priority with other elements like the wall.
Decide what is your hierarchy in matters of settings.
