Mac_the_arc
Beams not showing in section or 3d
Im trying to get a beam to show in section. I know it is there from the blue line and black dot. I can see the columns it needs to connect to.
2 Solutions
The Building Material material priority will need to be higher than the BMAT's of the wall.
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC29 | WIN 11 | Ultra 9 285K, 3.7Ghz | 64GB Ram | RTX4000
Go to post
Or change the Layer intersection priority for the layer your beam is on.
Director | Skewed
Go to post
6 Replies 6
jl_lt
Ace
is there a wall that doesnt show because there is a window the same size of the wall?
Mac_the_arc
no, ive hidden the wall for the purpose of the query
Director | Skewed
Director | Skewed
Mac_the_arc
Thanks you, I changed the layer intersection priority and now these are showing. very helpful.
Botonis
Mentor
Changing the layer intersection priority also means that you overide the material priority with other elements like the wall.
Decide what is your hierarchy in matters of settings.
