2025-04-25
06:43 PM
2025-04-28
02:51 PM
Im trying to get a beam to show in section. I know it is there from the blue line and black dot. I can see the columns it needs to connect to.
Solved! Go to Solution.
2025-04-26 03:01 AM
The Building Material material priority will need to be higher than the BMAT's of the wall.
2025-04-26 03:01 AM
Or change the Layer intersection priority for the layer your beam is on.
2025-04-25 08:51 PM - edited 2025-04-26 11:35 PM
is there a wall that doesnt show because there is a window the same size of the wall?
2025-04-25 11:50 PM
no, ive hidden the wall for the purpose of the query
2025-04-26 03:01 AM
2025-04-26 03:01 AM
2025-04-26 01:00 PM
Thanks you, I changed the layer intersection priority and now these are showing. very helpful.
2025-04-26 01:20 PM
Changing the layer intersection priority also means that you overide the material priority with other elements like the wall.
Decide what is your hierarchy in matters of settings.
