Roof Display Problem: advice needed
I have a gable roof that is overframed onto another gable roof, but the eaves of this roof go under the roof that the ridge runs over (confusing??).
Here is a perspective to give you an idea. My problem is, on the roof plan, I want it to show correctly, with the eaves hidden by the upper roof, but the ridge running onto the upper roof. If I change the display order, the entire roof will display above the other.
17 Replies 17
Ah yes, the porch roof is overframed, so not true valley's as Stuart has shown.
David Maudlin
Steven:
I was able to get this result by using 2 Multi-plane Roofs, and using the Connect command to Trim the lower roof with the higher roof.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
The upper roof is a complete gable roof, with no cutout where the lower roof comes in?
David Maudlin
I was able to do this with a two step process:
1. A. Select side roof as Target
B. Select main roof as Operator
C. SEO operation: Subtraction
2. A. Select side roof
B. Connect (from context menu)
C. Select main roof
D. Select part of side roof to keep
I have found that experimenting with two operations can achieve results not possible with one.
David,
Very interesting, thank you. I've used SEO's a lot but I'm unfamiliar with the other options in the connect menu. Which did you use for the second step? {when you say "connect (from context menu)"}?
David Maudlin
Steven:
I think this easier to do in the 3D Window. Select the roof, then right-click to bring up the contextual menu, and select Connect > Trim Elements to Roof/Shell. This is a new way of working so you should take a look at the Help files, such as: Virtual Building > Construction Elements > Trim Elements to Roof or Shell > Trim Particular Elements: Manual Trim.
Will do, thanks again!
