‎2007-12-07
06:08 AM
‎2023-05-23
03:14 PM
Rubia Torres
‎2007-12-07 07:46 AM
Hunter wrote:The best you can do is "Model it as it is built".
Just trying to see where people usually place their roof pivot lines with respect to the walls they are sitting on. Do you place the roof pivot line to the inside or the outside of the wall? Or do you place them elsewhere? The inside would give you a birdsmouth right? But it's not always correct. No method really seems entirely correct.
Any comments?
Hunter.
‎2007-12-08 12:26 AM
‎2007-12-08 04:38 PM
‎2007-12-08 07:51 PM
‎2007-12-08 10:27 PM
‎2007-12-10 12:28 AM
‎2007-12-10 09:58 PM
Matthew wrote:that about sums it up. i often find that the pivot line gets all out of shape once some editing has taken place anyway: once they're initially placed i tend to edit them in the 3D window - elevating, stretching and pivoting from there. where the pivot actually ends up is anyone's guess . . . just as long as the roof is in the right place, eh?
The roof pivot line should be placed at whatever is the known defining elevation of the roof. In some cases this will be the plate height, in others it will be the dripedge, and in others it may be the ridge.
‎2007-12-11 07:32 AM
