Scott Newland
Roof edges: Complex profiles possible?
It doesn't seem possible to apply a complex profile to a roof edge. Is this true, or is there an ArchiCAD 14 method that I don't know about?
Scott J. Newland
Mac OS 26.5.1
ArchiCAD 29
iMac running OS 11.5
4 Replies 4
David Maudlin
Scott:
You are correct. There might be a wish on the forum to add this feature, I know it has been discussed before.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
A possible solution is to create a Custom Profile in the Profile Manager and assign it to a Wall or Beam.
Then draw that Wall/Beam along the Roof edge you want to see as custom.
Then perform the necessary SEO between the custom profile Wall/Beam and the Roof.
This Wall/Beam can reside on a custom layer which is hidden and wireframe. This way you will only see the result when you hide its layer.
Stress Co_
David wrote:
There might be a wish on the forum to add this feature,....
2003 WISH and 2006 WISH
Marc Corney, Architect
Red Canoe Architecture, P. A.
Please see this thread. It may be relevant to what you are trying to do.
http://archicad-talk.graphisoft.com/viewtopic.php?p=103276&highlight=raking+molding#103276
Peter Devlin
