ā2005-02-15
02:45 AM
ā2023-05-23
03:37 PM
Rubia Torres
ā2005-02-15 02:53 AM
ā2005-02-15 06:20 AM
Steve wrote:For some reason, after much trying, this actually did fix the problem this time! I have searched this forum before and come up with this fix but it has never worked. What took the time was trying to get the select tool to select either edge while zoomed in (so close together!) and then trying to figure out which was the higher edge to get the lower to meet! See attached drawings for more problem detail.
Ctrl-click.
In 3D, Select the roof with the highest ridge - press Ctrl and then right click on the low ridge.
ā2005-02-15 06:24 AM
ā2005-02-15 06:26 AM
ā2005-02-15 06:28 AM
ā2005-02-15 06:30 AM
ā2005-02-15 06:31 AM
ā2005-02-15 07:07 AM
ā2005-02-15 09:31 AM
Colin wrote:I think you may have found a consistency problem. If you have a look at the image I have attached, you will see that you can choose to have all of the joins, edges vertical.
Section view at the ridge.
