Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Roof section line
Hello,
I am wondering if there is a setting for roof to remove that line. It shouldn't be there i don't know why it is showing.
Thanks
3 REPLIES 3
Hello drexdis,
Did you check that you are using the exactly the same material into your composite roofs to make this line invisible ?
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
Is is only one roof, made with marquee over contour line.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hello,
Thank you for the question!
With the limited information from the screenshot, it is very difficult for us to identify what went wrong with your roof. I'm wondering if you could share the file for further investigation? Please let me know if you need a secure place to upload the file also.
Looking forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
