Roof section line
I am wondering if there is a setting for roof to remove that line. It shouldn't be there i don't know why it is showing.
Thanks
3 Replies 3
Hello drexdis,
Did you check that you are using the exactly the same material into your composite roofs to make this line invisible ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Is is only one roof, made with marquee over contour line.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for the question!
With the limited information from the screenshot, it is very difficult for us to identify what went wrong with your roof. I'm wondering if you could share the file for further investigation? Please let me know if you need a secure place to upload the file also.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
