Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Roof squares
Greetings, is there a way to calculate roof squares or square feet of roof surfaces?
Thank you very much.
2 REPLIES 2
Erwin Edel
You can create a schedule for this or if you want a quick look there is the Element Information palette.
You can also create lists, but these take a bit more work. There should be Calculation Guide PDF linked from the archicad help menu if you want to dive in on the deep end on that one.
If you want to read up on schedules, the Reference Guide (also available from the help menu) has you covered under 'Documentation > Calculation'
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thank you Erwin, I know I'm a bit late in responding but I really appreciate the info.
